Motor and esc problem
Followers (4)
- GregHiltzGold
Life has been great ever since, you should do great.
I have set of plans for the HMS Snowbird Corvette, which I could get blown up to any larger scale if you were interested.
Cheers!
Ive bought a 2-1 gearbox, and may go with a smaller prop, currently a 40 mm triple course one, (no idea of pitch)
i also think, theres no escape for heat in the engine room, posh word for electric motor area!! so perhaps some ventilation is required as well, so a PC fan, has been nicked, to aid in exporting heat
steve
Increasing either voltage or amps increase the wattage and if you exceed the max the motor will overheat. I suspect your coarse prop is the problem as it is overloading the motor and increasing the current draw. If you change the prop to a smaller diameter and less pitch it will reduce the current drawn and your model will perform much better. Three bladed brass props will give good results and I would avoid the two bladed racing props. As a general guide the prop diameter should be less than the diameter of the motor casing.
It is a case of trial and selection so good luck.
But if the 540 is a 4.5-15v motor, (it says that on the motor) how can a constant 12v be a problem?
I would like a gearbox, but have no idea of were to get one, unless i make it,
Yep, its direct drive, and the prop is quite coarse, but weirdly, i was thinking more akin to a 2-1 motor to prop gearbox, to relieve the moto speed but increase the prop speed,
but what do i know. obviously, NOTHING !
Choices aren't go with a Hi-Torque 5000 rpm 775 Motor direct drive, or add a 2:1 or 3:1 gear reduction to your existing motor.
Its now running a 540 motor (4.5-15v motor)
A 12v ESC, and a 11.1 Lipo,
Todays running on water, was pretty sedate, at full throttle, almost disappointing! yet after 10 mins of motoring about it was down on power, so i brought her back and the motor was BURNING hot, ESC and battery seemed fine,
Im surprised the motor was THAT HOT, as at max it was only 11.1-12v max
So, do i need water cooling ? or a gearbox to offload some of the 540 speed to the prop ?
and to cap off a miserable day, one of my lift vests fell of the roof of the boat and sunk !!!
so we came home, hahahahaha
steve
Liked by
Loading…
