SURFACE DRIVE EXPERIMENT
Followers (5)
As before, it all vibrated insanely at anything more than about 5000rpm. The balancer reduced it slightly, but even putting 2 grub screws in the same hole to add more weight changed nothing. The ends are so badly out that nothing is going to fix it unfortunately. One of the biggest problems is that the CV joint has far too much side movement, and that and the Chinese machining error, added together is useless for anything high speed. Maybe tiny Teflon shims either side of the CV ball to take the play out might work, and a big hammer to straighten the ball end, but..................
I think I'll give it a rest for a while, till I think of something different to use. I think for this type of system, a cable may be the only answer.
CONCLUSION,- you can put lipstick on a pig, but it's still a pig😁
That truly is unfortunate, I really thought you had it solved🤔☹️
Trev
Made step up bushes for each end to fit the 6.8mm holes in the back side of the CV joints,(other ends are 5mm for the motor and prop shaft)- one was a press fit on the shaft and the other a push fit (so as to be removable) with a 3mm hole in the side for the CV grub screw to go though to grip the shaft. I fitted a 4mm flanged bearing in one end of the 8mm brass tube and left the other end (transom) open for now, as I may fit an Acetal bush for salt water use.
There is a Teflon thrust washer for each end of the tube. I'll fit an oiler tube as well. Also slotted the motor mount to allow for adjustment of the stinger drive. Hopefully this will be the option with the least vibration, - also won't need a seal on the transom. The experiment continues.
I do like the idea of an adjustable motor mount 👍👍
Would seem to solve a lot of alignment issues, thus reducing vibration.
Trev
Balance is not too bad with this twin CV set-up, but will require the mount holes slotting so the drive can be adjusted for angle (shaft moves back as you adjust down and vice versa) and a bit of precise motor positioning. I am thinking, if I can get this system working well enough to install it in the new model, I can leave the shaft hole open in the transom, and make a waterproof box inside to mount a seal (as I did with the Amphitruck driveshaft).
Trev
The old cable drive in the pic is still good after being thrashed for hours in a 40" Deep V Prather hull, with an O.S .45 FSR behind it. Hooked the in-runner up to it and it's still as smooth as silk (well almost) - better than the other stuff. I have a new complete cable drive which just needs the stern support bracket, so that will be the back-up I think.
Re support bearings, I thought that having an open shaft with a bearing at each end could possibly work, but in effect, it's the same as a normal driveshaft and tube, (might be safer,- nothing to grab hold of loose stuff). I need some brass driveshaft tube to make a new shaft up, as I have some new flanged 4mm bearings I can try, so I'll have a think about the next effort. With brass tube, I can solder on brackets for positioning.
I agree, supporting the shaft at both ends should work. Or a solid coupling at the motor end, but that would entail perfect alignment, or a floating motor mount?
Trev
I think you are right supporting the shaft at both ends should do the trick. Great work.
Stephen.
I've tried a number of good fitting true running plain couplings, and even the trusty silicone tube, but it really changed nothing, (even holding the shaft) Probably to do with the long unsupported driveshaft needing a solid bearing mount at the motor end. Next plan is a std prop shaft with bearings, supported at both ends to see if that helps.
I tried using the 36/52 in-runner for the test on 3s, and it will have plenty of power if I can get this working. If not, the model might just end up with a boring old std shaft😁 OR, a cable drive, (only drawback being cable drag on an electric motor, using extra power.) Either way it will move under its' own power eventually.
I'm keeping all of my old hand woodworking tools, 'just in case' (and my records lol) new isn't necessarily better in a lot of cases. We are constantly forced to buy new tech and upload everything older you have to it, as older stuff is phased out (records, tapes, CDs, DVDs/Blueray, (even flash drives, external hard drives etc are apparently only safe for about 10yrs before they should be replaced) I have records 50yrs old (not alone there) which still play perfectly, but it's hard to find a good turntable which doesn't cost a spleen these days.
Tech for techs' sake I think in a lot of cases. A bit like cars, - full of gadgets most people will never use, which would be better coming as plug-in options.
I always video all my planes first flights (and others) and it's amazing what you can gain from looking at the vid if something goes wrong, as you can quite often see the problem and correct it (as long as you're not going home with a shopping bag of bits)😁
Re frustration,-
I get frustrated waiting for 20 mins for an edited video to process, only for the editing program to shut down for an unknown reason, and to have to start all over again.😠
Recording, Editing and posting is a lot of work, can be frustrating. I have been remiss in this Regard.
Trev
Your posts are always clear and concise, with an outstanding amount of detail, so please keep them coming. 👍
It was demonstrating the amount of play in the Chinese couplings I was experimenting with. The reason it was grainy, was it's a cheap HD camera and it was at night. I's a good camera for close up stuff normally in the daylight.
Highly unlikely that a Dumbphone will have the CODEC to decode prehistoric AVI files.
You didn't miss much. The Toob version is the only interesting one anyway.
Cheers, an' G'night 💤💤😴, Doug
The first two aren't really worth the trouble. They are very grainy 360p resolution AVI files showing JB twiddling the various couplings. Why you have sound but not video is a mystery!
Have you tried opening the downloaded file with Windows Media player? Works for me.
The last one viewed on Utoob is much better, you can set the resolution to 1080p or higher if your device can manage it. It's also followed by JB's Tank Test of his Hartley Flareline water jet.
I thought about boring the rear end out and replacing the metal bush with an Acetal one, but I'll see how the originals go first. Used to run Teflon bushes in the ic boats years ago, and they lasted forever, and were a lot quieter than brass/bronze. Good for salt water as well, - unlike bearings.
Although are you saying that you will put Brasso onto the Acetal bushes?
If that's the case IMHO there could be a problem with the abrasive impregnating the Acetal and continuing to abrade after you want it to.
Stephen.
Uncharted Territory for Me 😂😂
Trev
Precedent Fairey Huntsman 46"
Veron Fairey Huntsman 28 42"
Precedent Fairey Huntsman 36"
Aerokits Sea Commander 34"
Aerokits Sea Rover 29 1/2"
SLEC Fairey Huntress 23"
Made up a rough dummy transom to test it out. Milled a bit more clearance in the back of the stinger bracket for the CV, made a couple of transom-drive brackets, (modified from hardware corner brackets,) made an Acetal bush to replace the usual cable drive in the back of the stinger, (to support the shaft rear), and a small 4mm-5mm adaptor shaft to go between the brass motor connector and the inner CV for the test.
There is a huge amount of slop in the Chinese connectors and the red d/shaft has a loose sliding hex inside, so not the smoothest running. Also no bearing in the transom to support the future one piece motor to CV shaft. The final shaft (test dummy) also is free to move in and out, but will be properly positioned once the stinger shaft is made, which should smooth things out. A steering arm to make as well if I can get it working properly.
Probably take a while to get it working smoothly and it may not even be suitable, but fun to try anyhow. Have built a shaft slot in the keel just in case 😁. Motor for the test was the slowest I had, and run slowly to avoid possible flying bits. The final motor will hopefully be the 540 S V-spec fan cooled 36/52 1100kv in-runner which I'll be water cooling. Had it for about 10 yrs, so decided it needed a home, (another experiment).
1 vid shows the amount of slop in the connector, which should be 0 if made correctly. This is why people have so much trouble with vibrations in boats. The only real way to fix it is to make your own and ream the shaft holes to size,-not drill them like the Chinese seem to do.
Liked by
Loading…
