Problems with RC Model Yacht Hurricane Racing Sailing Model
Started by Jimbob901
5 replies 6 likes Last activity: 5 years ago
Hi Dave976 thank you for your reply have been in touch with Volantex & found out the winch etc is all factory set also ordered a couple of spare reels of twine just in case I think I am almost there but its a bit fiddly 👍
Hi Jimbob901
I have looked on line for details of the Hurricane and see it is an RTR model from Volantex. according to the specs the radio is in a self contained box in the model and all the difficult parts of the rigging are pre installed. Instructions are provided to allow the purchaser to attach the sails and rigging so if it is this part that has become tangled then removing and refixing according to the instructions should solve your problem. As others have correctly stated there are many ways to rig a yacht and there is much help on line and via Utube to see how to proceed.
Your model however has a sealed bespoke system and I suspect uses their own design for the rigging so is probably not modifyable.
If there is a model boat club near to you I suggest you seek their advice as there will be experienced yachtsmen who may be willing and able to help.
If any member on this site has a Volantex Hurricane yacht I would hope they would offer their advice as that would be comparing like with like.
My own club sails similar RTR models and they are generally good sailers but my RG65 was an early version and was not the easiest to rig initially but sailed beautifully.
Good luck and I hope you can find the help to fix your model
Dave976
Liked by Colin H
I use IOM yachts and I think the winch should be similar on your yacht. I am including a link to the winch type I have used as it has a diagram of the layout. In order to maintain tension on the winch drum you need to create a loop with a spring or elastic to maintain tension. The line to the jib and mainsail are connected to the loop. This the link https://www.rmgsailwinch.com.au/rmg/pages/UserGuideG.html
You will also find help on the MYA website here https://www.mya-uk.org.uk/
Liked by Colin H and dave976
Some years ago I rigged the inside of an RC yacht and it was always going wrong and because it was hidden under the deck it was a problem. The lines were always getting tangled.
I put it all to one side for a year or so.
Then I decided I must work out why. I released the unit and brought it out into the open and it seemed to work OK. Then I realised my error!
I had attached the jib line to the elasticated return line, it should have been on the winched in side of the lines.
All works fine now and an easy error to make.
Liked by dave976
Winch can be rigged a few different ways. Some winch spools run a trolley that you attach the sail line to whilst others are just direct drive (spoiling it up and running it out the rear loop). But that last way needs some sort of cord retainer or it will unspool freely when there is no load. Which might be missing on yours. In that case, either get a new spool or use a long servo arm🤞Good luck
Liked by dave976
Hi Model Boaters I am a newbie to RC Model Yachts so I purchased a pre made kit from eBay.
I have encountered issues with the re threading of my sail winch servo
after it got into a right mess is there anybody who could offer me any useful advice " Yes shouldn`t have bothered stick to electric RC boats"
Liked by dave976
