Billings Tug Banckert
Started by Colin H
15 replies 25 likes Last activity: 5 years ago
#16 1
Thanks guys information and pictures were a great help.
I will probably use sla batteries as I have plenty.
Also motor selection will be from stock, could possibly be a geared 540 or similar size.
Will definitely be 2.4ghz as I also have stock available.
So once Xmas is over I'll be trying to fit her out with all the necessities, trying not to damage her as it is a lovely model.
#15 1
your are welcome with lipo's you will need to add lots of wieght for ballast and there is not much room for everything it's a tight fit.
Liked by Colin H
#14 1
Hi, I built one about 10 years ago, only problem I found was it needed a lot of ballast to get it to sail low enough in the water, and ended up fitting 2 x 6volt 4Ah batteries one under the superstructure and one amidships but used a 385 motor fitted to a 2.5:1 reduction gearbox. The result was a tug that would run for several hours with no problems. I still have it, but it just sits in the model shed these days. Radio gear was kept simple rudder and electronic speed control. There is photo in my harbour.
https://model-boats.com/harbour/19612
Liked by Colin H
#13 1
Good morning Bruce, thanks for your reply, very helpful.
#11 1
Hi Bruce, can you tell me your setup as I have a blank canvas.
Any suggestions welcome and helpful.
Cheers Colin
#10 1
JB, I think I will keep it as it was built, but adding radio gear and motor from my stockpile. My idea is to use it as a maneuvering trainer for my grandson, and any other youngsters at the waterside.
Needs to be a low rev motor with plenty of torque to give realistic handling.
Liked by jbkiwi
#9 1
Hi Colin, can't help yourself can you,😁? nice find, will you be doing the usual cosmetic improvements, or keeping it as is? Would be nice to get it on the water with some modern gear.
Liked by Colin H
#8 1
Say no more Rick 🙊
Nice one Cyril👍 Er ... Colin😉
Looks fairly well put together.
Keep us posted about the fitting out please.
(Coz if you don't I'll be compelled to send Caroline a firmware update for the kit detector to raise it's sensitivity to started or completed kits 😁)
Liked by pressonreguardless
Nice Find!!!
Liked by Colin H
I built that kit in 78 have since up graded it to new electronics and motor ESC It is still running.
Liked by Colin H and RNinMunich
Nice catch!
Liked by Colin H
Good evening all, although not actively building at present I am still here, stupid health issues aside I'm gathering more models.
And this is my latest acquisition, a billings Tug from the early 80's.
Just so good I couldn't resist it, luckily the wife's kit detector failed to pick it up as it's already been built.
Just needs the electrical system installing.
Liked by GaryLC and MouldBuilder and
