ABS plastic sheeting
Started by Allan
14 replies 10 likes Last activity: 5 years ago
Try Antics
It really doesn't matter if the sheet is to big for you at the moment Allan, I'm sure you will find a use for it in the future, I keep a stock of sizes 10thou to 80thou
and the good thing is, it doesn't eat much😁
Cheers, Pete
Thank you very much, I did have a look on Amazon, but most had long delivery dates. I'll check out the Modellers shop , I located a sheet, but it was much larger than required. Many thanks.👍
Liked by dave976 and Rookysailor
Hi Allan,
Have you tried AMAZON, they have quite a few choices for plasticard sometimes referred to Hips.
I presume that is what you are calling Abs SHEET,
Also online is 'The New Modellers Shop' they seem to have quite a choice.
All links below👍
Cheers, Pete😊
https://www.amazon.co.uk/WHITE-PLASTIC-PLASTICARD-0-75mm-SHEETS/dp/B00F6S94SA/ref=sr_1_5?adgrpid=108047720767&gclid
https://www.newmodellersshop.co.uk/plasticard.htm
Liked by dave976 and Allan
Try your local department store signs used for advertising or other such.
You could try a company called Kit Form Services, although Howard sells Resin models he also has a section in the menu for Evergreen plastic extrusion and plastic sheet all of various sizes.
Thanks everyone, I'm on the case now, much appreciated to you all. 👍😊
Many thanks, much appreciated👍
Hi Colin
That is very helpful, much appreciated.
Allan
I have bought a lot for my railway from ebay all from the UK.
j a Easter.
Liked by Allan
Alan, another supplier I've used is:- PerspexSheet.uk
And do next day delivery if required.
Liked by Allan
Hello. ABS Plastic Sheet
Bay Plastic CO.UK
Seams to be others on line UK.
Rick
Liked by Allan
Hi Alan, have you checked,
plasticsheeting.com
I've used them for various types of plastic sheets and always been impressed.
HI, I wondered if anyone knew where I could source a small sheet of ABS plastic. I've tried on selling sites but the vast majority appear to come from China. Its more to do with time scale for delivery. I'm trying to source somewhere in the UK? wondered if anyone was aware of a more local source to try? Many thanks 👍😁
Liked by dave976
