SILICONE TUBE COUPLING
Followers (1)
Much food for thought, but am now confident enought to continue.
The sailing season is all but over in Canada. Will upgrade a couple of models over the winter to silicone tubing.
Will report back next Spring with results.
Rowen
Small low powered models work fine with silicon fuel tubing as the power and revs involved are normally low.
As jbkiwi says he intends to use his lathe to make a more substantial fitting for small spaces.
On a more powerful planing type craft the revs and power will be much greater and more substantial silicon exhaust type tubing works better. Space will not normally be a problem. This does have a larger internal diameter so you do need a bush on both the prop and motor.
If you have access to a lathe then these can be turned from brass and grub screws fitted to lock. You may need to put a pin thro the silicon and bush if friction does not prove sufficient. Huco coupling brass inserts may also be used and as they are splined work well to grip the tube.
I have used both types with success, but would not personally use silicon with any brushless motor as they produce a great deal of power and need good a good solid mounting and drive train. Any problem with either and you are likely to see magic smoke or worse and there will be little or no warning, as I well know.
regards
dave
For anything reasonably powerful, you can fit a firm plastic tube which just fits over the silicone, and force the silicone onto the shafts. My Hartley jet boat can pull 30A with a 3000kv 45D brushless inrunner on 3s, and it seems to handle it ok. On brushed motors or brushless inrunners, you will need to make a 'stopper' at the motor end to stop the tube migrating up to the front bearing, (see my vintage runabout post on this).
Now that I have the lathe, I will be working on a better system for utilising silicone tube, especially in confined spaces, as most of the couplings of this nature (I think CMB sell a few of this style with a captive silicone or rubber insert) are too long for a lot of tight spaces (not to mention expensive.
The couplings still look like new after a couple of hours running. The shaft size is 2mm, the motor is similar.
This experience has been encouraging, am now thinking of removing the exisiting steel universal couplings on a larger model.
This model has twin 30mm screws, 1000kv motors, runs on 3s batteries with shaft sizes of 4mm.
Has anybody any experience of a similar layout and what would be your thoughts?
Thanks
Rowen
Liked by
Loading…
