1 reply2 likes0 followersLast activity: 5 years ago
Hi Geoff,
I might be wrong but if the drawings are from 1952 then i would imagine the weight would be lbs/oz.
As we would of used imperial measurements back then in the U.K..
Hi Geoff,
Those that are following my blog on building the Dutch Auxiliary will know that I am working from a rather sketchy plan from 1952. When it comes to the amount of keel weight required the plan gives no indication as to what it should be. lbs/kg Perhaps someone could give me a sensible starting point for the hull which is 16 inches by 7 max beam (410x 189mm) All answers on a postcard or here on the site. Many thanks Geoff.
