Boat Build Help
Started by WellsBoi
245 replies 524 likes Last activity: 5 years ago
#146
Boat Build Help
I have found some english oak in my store that i can cut down to make the full size frames
Liked by Martin555
#144
Boat Build Help
Yes but they did move very quickle with the Gardener engines
#143
Boat Build Help
Wellsboi,
a simple piece of advice join a local club as the members there a very helpful.
I would not suggest you go brushless with Lipo / Life batteries. Incorrect use and maintenance can end up a disaster Suggest Brushed Motor and NiMh Batteries easy to care for.
Remember that this is a fishing boat not a high speed cruiser
Ian
Liked by Scratchbuilder and RNinMunich and
#142
Boat Build Help
WellsBoi, I agree with Ron. Keeping your first build simple certainly has a better chance of success than using equipment beyond the need of the model.
It would not be productive to over-build the running gear in a model that isn't designed for it. I think you'd be much happier with a fishing boat model that acted like a fishing boat.
The list that Ron provided is ample for a first build. When this boat proves out and you're comfortable operating it, then look to the next build and expand on what you've learned from this one.
Good Luck!
#141
Boat Build Help
Interesting thread as my family had a house and speedboat in Wells in the 1980s and remember the area well and I've also produced plans and built a model from a small photo - in my case a Fairey River Cruiser prototype.
I must go through my box of photos and see what I've got of Wells - not that I used to take many in those days.
Liked by WellsBoi
#140
Boat Build Help
I walk by it when i take the dog out so know where it is
#137
Boat Build Help
Ive arranged to book an appointment at the local hobby shop for some Balsa wood as he click & collect only due to the covid restrictions
#136
Boat Build Help
One guy on your tube has done a comparission test on a boat on both with brushed and with brushless in the same boat at differant times and found better results brussless motors and litho batterys with a speed control giveing better performance with less weight
Liked by Griss
#133
Boat Build Help
Hi Ron.
You are doing a fantastic job on these drawings.
Maybe one day you could do a 'How-To' Article on this subject (from photos to drawings)
Liked by Scratchbuilder and Madwelshman and
#130
Boat Build Help
What Motor/Servos/speed control /Battery would be sugested for 39" model
#129
Boat Build Help
Ianh
I was thinking i aleady have a trailer that would take two boats but need to measure the inside first as iam not sure what size it is .I would have to make a cradle for the boats aswell
Liked by Martin555 and Ianh
#128
Boat Build Help
As the original was 39 feet and taking 1" to the foot the easiest scale would be 1:12 which would give you 39" Model Length
If you work in 1:10 Scale the boat would 46.8" Long
Liked by RNinMunich and stevedownunder and
#126
Boat Build Help
Ron
Which one is correct is up for debate lol
As Remus had the refit after the leggatts sold the boats when Alf & George`s retirement came along
Remus had the new wheelhouse longer than the origanal
However i prefer the one it was built with and it will be Varnished
I have asked Alan to look at andersons records about any refits R&R had
#125
Boat Build Help
I felt it strange that as both were built as a pair Remus had a differant wheel house .Maybe to accomodate either George or Alf`s height However it was rebuilt in the 70s possable at adersons.
#122
Boat Build Help
"just sent you a PM "
OK Ron, got it - a Real email. Thanks👍
I can import your Autocad files into either Corel Draw or Corel Designer.
To get them to show up properly in a JPEG or PDF export though I had to thicken up the lines from hairline to 0,75 or 1mm! Scaling for David could be fun as well.
Sample pdf attached.
More tomorrow, which it has been here for 4 hours now 😴💤💤💤
G'night All, Doug 😎
Liked by Martin555 and stevedownunder
#120
Boat Build Help
Try searching the internet for dfx reader
Liked by Martin555
#118
Boat Build Help
"the last picture is the only with a sliding side entrance to the wheelhouse."
That one has been totally rebuilt Ron.
Much narrower and thus only one window.
I'd go for the full width / two window job.
Cheers, Doug
Liked by WellsBoi
#116
Boat Build Help
I'd go for the original varnished version Ron.
The one with angled front and two windows.
I believe that that is what David wants to do.
BTW: From the draft Plan/Profile you posted below it seems like you've already made a good start👍 and your Autocad can export in JPG format OK for David. So you're up and running😊
Liked by WellsBoi and Martin555 and
#113
Boat Build Help
Hi Ron,
I have Corel Designer / Draw / Technical Suite + trimmings.
I can (🤞) import Autocad dwg and dxf but I don't recognise dfx🤔
Let's suck it and see!😝 or 😋
#111
Boat Build Help
Ron
I wounder if its the same Mr Dudley as ive got listed as designer? A C Dudley
I have had to change the pic from bmp to jpeg
ps Maybe Mr Dudley family has archive material ?
Liked by Martin555
#109
Boat Build Help
They were given me on Ship Nostalga but that was years ago and ive since looked as i can not post that info pic for some reason and there not on there anymore
It list Remus and Faustulus with the deatails i have mentioned
#106
Boat Build Help
A question over weather the boat designers A C DUDLEY who were the designers still exist with the plans as i can not find any mention of them on the internet
#105
Boat Build Help
A later pic of Remus as the wheel house has been removed and the cabin has been taken back to its origanal finish &
Early origanal transom
#103
Boat Build Help
Ron
Yes i know and the current owner has replaced the transom
Liked by Ronald
#99
Boat Build Help
I had wondered if Andersons ect had taken on R J Perkins &Sons after they folded and weather the plans had moved with the new owners but with Andersons folding aswell in the 70s ? i had hoped the documents Plans may have been saved by someone ? but the museum hasnt got back to me yet.Maybe with the covid there not open .
#98
Boat Build Help
Ron
Only the three Leggatt boats had the differant transom`s Romulus,Remus & Faustulus.How far out do you think the center line was ?
However the general build was similar to other boats
