Brushed Motors 24V
Started by Toylander
0 replies 0 likes 0 followers Last activity: 15 years ago
Brushed Motors 24V
HI all, I've got a few brushed motors that are rated at 24 volts, and no other Information. Running them at 24V with no load they pull 0.9Amps, at 12v 0.78Amps. They are 60mm In diameter, body length 115 mm shaft 40 mm shaft dia 6mm. Rpm Is estimated at 8000 rpm at present as the measuring device seems broken, will be re-measured when the replacment arrives.
Update the motors are from patient electric hoist's that could lift up to 300Kg's
Is this motor any good for a boat? I was thinking of using It In a Sea Queen.
Any way as I have more than I can use, Is there anybody who might find use for the others? free to a good home, first come first served for the cost of postage.
Update the motors are made In Italy,
All motors have now found new homes.
