Hi Pete,
Yep, the colour of the LEDs can be determined by doping the diode chip with various elements. The early ones were either red or clear, so the colour was added in the epoxy dome around the chip.
Cheap ones still are like that.
Nowadays you can get LEDs that light different colours according to the voltage applied! For instance in those irritating shelf / vitrine light strings that rotate through a variety of colours all the time.😡
I have some that are red or green depending on which way round you apply the voltage! They are milky white when off. Useful for checking the operation and setup in the boat of brushed ESCs and motors, esp for multi-screw boats, and the output of switching circuits.
Funny I always thought halogen lights were a hard white with a blue tint, like some car headlights. Cool on the Kelvin temp range.
Yellow is more like the warm white light of a tungsten bulb to me.
Yellow deck floodlights are more likely to be sodium lamps, like many street lamps.
The measurements you sent me indicated that the switch on voltage (Vf) of the searchlight was 3V and all the others 2V. So I based my final calc on that. if any of your LEDs don't 'strike' with 150Ohm just reduce the resistor to 120 to give it a 'shove'😁 I don't expect that though.
I have a box of 300 various LEDs and 1000 various resistors in front of me (and the mast from my Southampton tug😉) so will do some practical tests.
BTW: I can strongly recommend that you buy a simple LED Tester, like one of these-
https://www.ebay.com/bhp/led-tester
I'll help you get the LEDs the right way round in your circuits and tell you how much current they need for a decent brightness, and at what voltage they will turn on! Only a few bucks and saves a lot of aggro.
It'll also tell you what colour a 'clear or white' one will be when it turns on😊
