Graupner Elke HF 408
BTW Allen, Dave's comments re 'old motors' go in the right direction but the basic thought and measurement technique are not quite right.
There should never be ANY ohm meter reading between armature coils (i.e. motor supply connections) and case! Do by all means try this, but anything less than infinity, '---' on most digital meters, means a scrap motor😡 This test really requires an insulation test using what is commonly called a Mega meter. This has a crank generator which puts high voltage (ca 1000V+😲) across the unit under test. it measures the insulation resistance in millions of Ohms, hence the name Mega!
For us modellers not a particularly useful or practical test!
The most common form of deterioration in old motors is cracking and flaking of the insulating varnish of the armature windings. This does not normally cause shorts or spurious measurable resistance to the case but causes internal shorts in the windings thus reducing their resistance and therefore increasing the current they draw for a given voltage applied, as Dave indicated.
There are two ways you can check this, if you have a decent Ohm meter, one less, one more accurate.
The less accurate is done externally by measuring across the normal motor connections and thus include the resistance of the brushes and connections. Connect the meter where you normally connect the output from the ESC.
Slowly rotate the motor so you can feel the slight 'click' as the motor moves from one winding to the next (or one magnetic pole to the next if you like😉)
You should see a few Ohms resistance at each pole. Value depending on the quality of the carbon brushes. Better quality brushes (more copper content) = lower resistance. Note and compare each 'pole' reading.
If one 'pole' reading is significantly lower than the others then that winding has an internal short😡 The motor may overheat in that winding, depending on how many wires are affected, and fail eventually.
The more accurate method is to dismantle the motor and measure the winding resistances directly at the commutator, i.e. without the brushes in circuit. But this is only useful for nuts like me 😁 as in my 50 year old Taycol Target renovation. I was lucky no shorts and all windings same resistance + or - a gnat's whatsit!😊
Sooooo, to cut a long story sideways😉I think it's very unlikely your motor has any internal problems. I recently found one of the ancient Mabuchis I originally fitted in my HMS Hotspur destroyer 51 years ago, it still clattered along, bearings shot but electrically still OK 😊
Just take what you've got now down to the lake and give her a Go. if she looks right then she most probably is! As my German colleagues would say "Always a hand's width of water under your keel". Cheers Doug 😎
PS: "But trust me on the sunscreen" 😁
