1 reply0 likes0 followersLast activity: 13 years ago
Sounds an interesting project. it would be good if you could share your build by posting a build blog to share your progress with or members. You can start this by clicking on the Build Blogs appearing in the drop down menu below Photo & Video Gallery on the left hand side of the screen
I am about to start building the Cossack. The first step will be to make the mould for the hull, the mould will be made from extruded foam It will then be shaped to the profile of the hull. After the mould Is finished It will then covered with glass cloth and epoxy resin then placed Into a plastic bag then vacuum pump until the resin Is set. Once the resin Is set, the foam will be dug out and to leave the glass hull.
Until next time.
Happy sailing
[{"id":"1370300329","name":"1370300329.jpg","caption":"","url":"https:\/\/beta.model-boats.com\/media\/1370300329\/l","thumbUrl":"https:\/\/beta.model-boats.com\/media\/1370300329\/s","isImage":true,"ext":"jpg"}]
Until next time.
Happy sailing
