Modified Figures.
Started by Martin555
51 replies 81 likes Last activity: 7 years ago
#50
Modified Figures.
Hi Guys,
I was thinking about doing the How To guide on this subject.
And looking back through this thread most of it is pretty much covered.
So i think the best thing to do is if you have any questions then i will do my best to answer them.
Liked by MouldBuilder and Rookysailor
#49
Modified Figures.
Hi Peter,
I am not that good.
I just tinker and sometimes it works out ok.
#48
Modified Figures.
Hi Martin.
A
how to
guide is a brilliant idea. Your skills have no boundaries.
Ship builder.
Doctor.
Surgeon.
Decorator.
Electronics and computing wiz.
Teacher.
Have I missed anything?
Looking forward to seeing the painted finished item.😊
Liked by Martin555
#47
Modified Figures.
I modified a couple of Mountfleet figures for my last barge and stuck arms back on with Araldite. Perhaps I was lucky. Bought two for my current project at Warwick today, hope they won't need modifying.
Cheers, Nerys
Liked by Martin555
#46
Modified Figures.
Hi Pete, thanks been there, but it seems that the type of plastic that doesn't seem to stick with any type of glue. Even solvent plastic weld.
Liked by Martin555 and Rookysailor
#45
Modified Figures.
Have you ever tried a hot melt glue gun Colin? you have to work quite quickly, as the glue goes off fast!
but joints are sealed, and you can carve/sand off the excess.😐
Cheers, Pete
Liked by Martin555 and Colin H
#44
Modified Figures.
Thanks Martin, ah plastic welding, why didn't I think of it, especially as when I have used hot wire it has melted the plastic.
Just needed to be nudged in the right direction.
Liked by Martin555
#43
Modified Figures.
Hi Colin,
I have had the same problem in the past.
The only way i got over it was to heat up a scalpel blade that was held in a small vice, then with a pieces of the plastic that had to be joined (one piece in each hand) quickly rub the pieces on the hot blade at the same time and then quickly stick them together.
When set cut, fill, file, and sand until you have the required Finnish.
Liked by Colin H and jbkiwi
#42
Modified Figures.
Delicate cutting, but I find most of the small figures I have don't like being rejoined, I can't find a glue that works.
And so I have been rejoining by inserting a hot wire into the limbs. But its hard to hide the joints.
What's the secret oh master of the miniature limb manoeuvres.
Liked by Martin555
#41
Modified Figures.
Hi Colin,
This might help to explain what I have been trying to do.
Liked by jbkiwi and Rookysailor and
#39
Modified Figures.
Thank you for your wonderful comment Phil.
I will see if the other members would like me to do a How To.
Liked by philcaretaker and Colin H
#38
Modified Figures.
Hi Guys,
Thank you for your comments i really appreciate them.
It is not easy when you have the shakes LOL!
If you want me to do an How-To Article on this subject
Then let me know.
#37
Modified Figures.
Thanks for the information Peter.
I think that i will have to make things in 1:35 scale I future as it is easer to get figures.
Liked by Rookysailor
#36
Modified Figures.
Hi Peter,
I find the best aesthetic is Coffee taken regularly throughout the operation as it takes quit some time to do.
Not much good for the patient but good for the Doctor LOL!
#35
Modified Figures.
The Forum subject says it all ! - great one for an "HOW-TO ARTICAL" with summarised hints and tips ?.
Inspiring reminder of what can be done to achieve a satisfying end result !.
phil
Liked by Martin555
#34
Modified Figures.
Hi Martin, not sure myself, but 'O' gauge is
7 mm to 1 ft –
6.35 mm to 1 ft
Scale ratio various: 1:48 to 1:43.5
if that makes any sense to you!😊
Cheers, Pete
Liked by Martin555
#33
Modified Figures.
You've done a crackin job there Martin, think I might have a go myself, what anesthetic do I need?😐
Cheers, Pete
Liked by Martin555
#32
Modified Figures.
Amazing Martin, was just going to let you know about this set, has a load of extras with it, but of course you know that, good value for what's in the box.😐
Cheers, Pete
Liked by Martin555
#30
Modified Figures.
Well guys the operation went as well as could be expected and the patient is recovering.
I may have to reset his right wrist at a later date.
All of the final sanding and filling will be done prior to painting.
I just thought I would post this little operation to give you an insight to modifying figures.
Martin555.(Doc Martin)
The hardest part is holding them whilst you cut, fill, and sand.
Liked by MouldBuilder and Ronald and
#29
Modified Figures.
Hi Marky,
No I purchased these (see photo) some years ago and have only just decided to make a start on them.
Liked by Rookysailor and Colin H
#28
Modified Figures.
Doc Martin ,at least there's no blood🤣. are they the plastic soldiers you get in a big bag ?(as in toy story).
Cheers Marky
Liked by MouldBuilder and Martin555
Modified Figures.
Many a word said in jest Martin,it doesn't even go up with inflation😂
Liked by Martin555
#26
Modified Figures.
Doc Martin here again.
The second leg required the same sort of treatment, this time to make it more bent so that it will reach the ladder rung.
The upper part of the body is temporarily tacked in place so that I can work out the wedge size.
A LITTLE TIP.
When applying the filler it is best to go over the filler with a small brush with glue on it, this makes the filler more liquid and helps to conform to the contours of the folds and creases of the clothing.
More drying time required now before I can continue with the operation.
Before I continue I will have to give him a bit more anaesthetic as I don't want him to suffer any pain.
Liked by MouldBuilder and Rookysailor and
Modified Figures.
Tried amputating bits for the Miami Martin - could never get them back on - used a soldering iron in desperation - Had to bury those afterwards...... Good thing I was never a member of the Medical profession.......
Then thick superglue worked .....
So the rest look not too bad - if I could find them again.....
Liked by Martin555
Modified Figures.
Hi Guys Doc Martin here.
Well the anaesthetic has worked and he is out for the count.
I started by sticking him together with blue tack to give me an idea of what position he starts of at and what I have to do.
The plan is to have him climbing a ladder.
So the first job Was to cut off his legs.
The first leg needs to be straightened and twisted.
Small wedges cut from sprou was then glued in.
Now I need to wait for the glue to dry then a bit of sanding and filling is required.
Will post more as I go.
Modified Figures.
Marky you are only saying that because your pocket money is still the same as it used to be. LOL!
Liked by Rookysailor and marky
Modified Figures.
Hi Peter,
I am not sure but i think that "O gauge" railway figures are the same as 1:48 scale.
Modified Figures.
Martin found these on Ebay some weeks ago, and ordered a set, took about 3 weeks to come, but the are OK, says 1/40, but they are more like 1/48.
There are some military figures on the market, that have variable body parts!😁 in 1/48 & 1/32.😐
https://www.ebay.co.uk/itm/1-40-Layout-Workman-Action-Figure-Model-Toy-Figurine-for-Scene-Building-DIY/253863194521?ssPageNam
Cheers, Pete
Liked by Martin555
Modified Figures.
That sounds good to me Marky.
I think I will cancel the operation and just take the anaesthetic and stay in bed. LOL!
Liked by MouldBuilder and marky
Modified Figures.
Dr Martin 👨‍⚕️ As long as you use plenty anesthetic on the patient ,or if the worst comes to the worst on yourself (but only in small doses)🤣
Liked by Martin555
Modified Figures.
Hi Marky,
The scale is 1:48.
Tomorrow if I feel up to it I will do some more surgery on another German soldier.
He is booked in for surgery at 9.30am.
It is a long and complicated operation and has a 50% success rate.
Modified Figures.
Martin, remember in the Good old days you could get swappits where you could swap heads ,hands and arms,torsos and legs on the cowboys and indiansyou could also change their hats and headdresses you could also change the weapons they carried,also remember getting figures in cereal boxes .
By the way nice modifications to your figure ,what scale is he?.
Cheers Marky
Liked by Martin555
Modified Figures.
Thank's Jb,
It is annoying that there are not many manufacturers that make model figures for our scale ships/boats.
Having to make sailors from solders is a right pain.
I suppose i will have to call them Marines LOL!!
Modified Figures.
Hi Peter,
I know what you mean.
I try to get them doing something but unfortunately you cannot modify a lot of the plastic figures without doing major surgery.
If i had lots of figures i can then swap limbs and heads and cut and fill the gaps.
Some figures are so difficult that you actually have to grind arms/legs off completely and use wire and bits of sprue to make a new arm/legs.
Sometimes it seems more trouble that is worth but when you finally achieve it you look back at it and say it was worth doing.
It is a bit tricky to do i can quite understand why many modellers don't bother with it, but on larger scale models i think that it looks more complete with a few crew onboard.
Liked by redpmg
Modified Figures.
I had some crew on my Yorkshireman, in relaxed poses, but Doug told me to get them of their B***'s!
difficult to do, when you can't get figures in working poses.😐
Cheers, Pete
Liked by Martin555
Modified Figures.
Hi Ed,
Yes he is, although he will be sat on some boxes chatting to other members of the crew stopping them from doing there jobs.
Modified Figures.
Hi Peter,
Eventually he will be sat on some boxes talking to other crew members.
Modified Figures.
Thank's Colin,
I have a few more to modify.
If i can i will try a take some photo's at different stages.
Modified Figures.
Looking for crew to man a couple of the Thames Barge models I have built, I have found that modification seems to be the only way to get the figures you want, doing the things you want.
Nerys
Liked by Martin555
Modified Figures.
Hi Martin,
Nice job on the modification!
Is he the one that sits around while everyone else work?
I remember there were a few on my first ship.
That did the same thing!
Cheers, Ed
"Fair winds calm Seas"
73
Liked by Martin555
Modified Figures.
Lovely bit of modelling repurposeing.
Just a joy to see a master craftsmans work.
Keep up the good work.
Liked by redpmg and Martin555
