newbie
slowing your pace when riding through town
newbie
Sounds like you have connected the rx up incorrectly.
Try unplugging the ESC and plug the rudder into the socket you have just removed the ESC from. Make sure you plug in the correct way (black is usually nearest the case edge), the ESC was in correctly but in the wrong channel. Now plug the ESC into the rx. Normally on a two channel rx there are three sockets 1 (rudder)2(ESC) 3 (battery connection) The battery connection only has two pins, so there is no signal pin which could explain your problem.
If not the Eport lads will sort it for you
Happy sailing
newbie
newbie
newbie
newbie
I used to live on the Wirral and there are several clubs nearby.
There is one at E Port, they used to sail in the top lock basin on Sunday mornings. New Brighton has a club as does Hoylake, at the Lifeboat station and West Kirby in the park. Runcorn also has a club.
E port cover a fairly wide area so not sure which of the above might be nearest.
All have friendly members who will help you with your new venture.
newbie
newbie
Liked by
Loading…
